APs with 802.3af Power Over Ethernet?
Feb 05, 2006 6 Replies
William P.N. Smith
Ah, I found them on the US site, WAP54GP, thanks! Yeah, my POC5 (Power Over Cat5) hack is the lowest power solution, but the least standard one. At least it isn't destroyed by some of the low-cost "PoE" power injectors out there, like Linksys and Buffalo...
Can anyone reccomend an AP (not a wireless router) that works well, has good reliability, and has built-in 802.3af PoE?
I've done the Linksys WAP54G + WAPPOE thing, though it's bulkier and more power hungry than I like, and I've done the hardware hack to a WAP54G to feed power over unused pairs in a CAT5 cable, but that's not very "off the shelf", and is fairly labor intensive.
Anyone have any experience or reccomendations? I might need as many as a dozen of these things, and as several of them will be in the peak of a (lessee) 16-foot ceiling, I'd rather have ones that won't need frequent replacement.
Thanks!
There is an exterior one as well, WAP54GPE, but that really took him over budget.
Bob
Yeah, $200 and $400 is quite a bit of money, but in my case I'll be able to use a single AP with multip VLans to separate out guest from owner access without building separate public and private LANs, so it almost makes sense...
Yeah, WRT54G with DD-WRT firmware apparently does that too, I'm considering fiddling with that, but it's another support issue, and PoE is still separate or custom.
Thanks!
I've been installing the INEREPOCH 1700 series with real good success.
they have a whole lot of features for public free hotspots that my clients love. WPA, WEP , DHCP server, filters , etc. They are in a waterproof case for outdoor mounting, cat5 POE out the bottom and a type 'N" connector on the top, can be wall or pole mounted and are are 300 mw radio.
highgainantennas is the US distributor for the radios , located in Parker, Colo.
the IWE1700 is the middle radio in the above page
Richard, at Highgainantennas has been real helpful in getting the radios, ships quick and NO DOA's. If I order on Monday , I have the radio for installing on Wednesday.
I've got quite a few of these radios running in motels, coffee shops, and use them for extending the internet for people that can't get cable or dsl to their homes but have a friend close enough to use the radios from that point to the point needed.
hope this helps,
Bob Smith Robert Smith Consulting
I find the Netgear WG102 reliable and cheap enough for SME use
