Now with pictures!
Subject
- Posted on
Non-USB 11ac network adapters
- 07-10-2016
Re: Non-USB 11ac network adapters
No recommendation, but there seems to be plenty of 802.11ac PCI-e
cards to choose from:
<https://www.google.com/#q=802.11ac+pci-e+adapter
<https://www.google.com/#q=ac1900+pci-e+adapter
Jeff Liebermann jeffl@cruzio.com
150 Felker St #D http://www.LearnByDestroying.com
Santa Cruz CA 95060 http://802.11junk.com
Skype: JeffLiebermann AE6KS 831-336-2558
says...
Thanks, Jeff.
I was having a brain cramp and couldn't remember what my current 802.11n NIC
interface was and I didn't want to pull the tower out from under my desk and
open it up to look. It has a PCI-e interface. As a result, I was searching for
"11ac adapter" and 99% of the results were USB interfaces. To make things more
interesting, currently the distance from my router to my PC is almost 40'
going through 3 walls and a refrigerator. If I rearrange my office, I can
possibly eliminate one wall and the refrigerator interference.
Since my PC will be sitting under my desk, something with a cable between the
antenna and the interface that would allow the antenna to be at or above the
level of my desk.
Bob
Thanks, Jeff.
level of my desk.
Bob
Y'er welcome.
That will help, but going 40ft through 3 walls and a fridge seems
rather marginal. I don't think it will work with an internal 802.11ac
card and will probably slow down to 802.11g speeds.
Several ideas:
1. Locate the antenna as high as possible to miss the fridge. Use a
USB 2.0 802.11g or 802.11g/n adapter mounted on the back of a panel
antenna. Something like this antenna:
<http://www.ebay.com/itm/121580548418
and this radio:
<http://www.ebay.com/itm/111855845727
Note that with a 2.4GHz only antenna, a dual band radio is a wasted
effort.
2. Attaching a single external antenna to an 802.11n or ac radio is
another wasted effort. However, if you must have an internal PCI-e
card, all you'll find are dual band and 802.11ac radios. The trick is
to find out which external antenna is the "main" antenna. Plug your
external antenna into that SMA connector and ignore the others.
3. You can buy external 802.11ac antennas:
<http://www.l-com.com/content/Article.aspx?Type=P&ID=10425
I don't have any experience with these and don't plan to in the
future. You're on your own here.
4. Try a range extender or wireless repeater.
<http://www.linksys.com/us/range-extenders/c/wireless-wi-fi-range-extenders/
I've had lousy luck with most installations, but a few do work. The
trick is to put the store and forward repeater in a location where it
can be "seen" only by the end points and the end points can't see each
other. You may need to hide behind the fridge to make it work.
5. Switch to power line (HomePlug) networking AV2 (AV600/AV1200).
<http://www.homeplug.org/tech-resources/hpav2_next_gen/
Much depends on how much electrical noise you find on your AC power
lines. If you initially experience dropouts and streaming stalls, it
will get worse and you should try something else.
6. Last resort... run CAT5.
Good luck.
says...
I ended up getting the the ASUS PCE AC68 with the external mount antennas.
I now have a consistent 5 bars of strength and average 700 Mbs between the PC
and router simply by putting the antenna mount on top of my desk. It's still
going through 3 walls and a refrigerator. It will be interesting to see what
happens when I rearrange the office and eliminate the refrigerator and one
wall from the equation.
Thanks for everyones comments.
Bob
Bob
Congrats. I suspect that the 700 mbits/sec is not your measured
throughput, but rather the connection speed. Most connection managers
will show really impressive speeds, when they're not moving any
traffic. I would be really impressed with the Asus router if it could
do that through 3 walls. Try one of the benchmark test programs, such
as iperf3 to see how you're really doing.
Jeff,
I suspect you are correct about that being the connection speed. Since my
internet connection has a max rate of 200 Mbs, I would never expect to see an
actual throughput anywhere close to that. I do have multiple devices on the
network, but in general, never transfer anything between them.
I do have AT&T fiber to my exterior wall with GigaPower available, but since
they want me to pay 50% more for them to supposedly not snoop on my traffic, I
told them I wasn't interested.
Bob
Site Timeline
- » Is it theorectically or practically even possible to mooch off if a typical WISP
- — Next thread in » Wireless Networking
- » EnGenius Technologies Long Range 11n 2.4GHz Wireless Bridge/Access Point (ENS202)
- — Previous thread in » Wireless Networking
- » Can you get a USA Ham Radio license WITHOUT giving the gob'ment your SSN?
- — Newest thread in » Wireless Networking
- » 'No Company Is So Important Its Existence Justifies Setting Up a Police State' &...
- — The site's Newest Thread. Posted in » General Telecommunications Forum
