Hi folks,
Can anyone recommend some good/reliable USB 802.11b adapters? What's the best deal to be found right now? Also, has anyone attempted using this type of adapter with a Mac OS X or Mac OS 9?
Kind regards,
-Wendell
I use the D-Link DWL-122. I have had no problems at all. I have not tried it with a Mac, but the manufacturer says its compatable. They can be bought for around 40.00 USD new, cheaper on EBAY.
Read the full replyHi folks,
Kind regards,
-Wendell
I think you should be looking for best quality & reception. I bought 2 Orinoco 8425 WD 's 20 months ago, both work great, one at either
80m trough two windows, the other trough a floor and two brick walls over ~25m. Regards, MartinHave something to add? Share your thoughts — no account required.
