Hi
Does anyone know if you can connect an external antenna to a Netgear DG834G.
I need to mount the unit in a cupboard a floor level and figure this is not an idea place to allow decent propagation! Thoughts were to mount an external antenna higher up in the room.
I've checked the Netgear site but couldn't find any reference to external antenna fitting.
If anyone is doing this with an internal (i.e. inside the house) external antenna (does that make sense?!) than can you let me know what model you use and if you are happy with the set up.
Many thanks
Jonathan Nottingham, UK
