Hi all,
Is it possible to configure linksys wireless through browser? What's the port to connect to?
In the wireless window, it shows my router is open for public use, while most of the other people's computer is protected...
Thanks.
-- Jack
Hi all,
Thanks.
-- Jack
If your Linksys router has the default settings, then clicking on this link will bring up the config page: http://192.168.1.1/Leave username blank, use 'admin' (no quotes) for the password.
Lance
*****jacksu thought carefully and wrote on 12/17/2005 4:05 PM:
very interesting...
NSLOOKUP resolves to the local address, as does PING.
Do you have the history >>If your Linksys router has the default settings, then clicking on this
Netgear does that on initial setup. You connect to:
I use various Dynamic DNS services to find my custmers routers. I'll probably regret this, but you can get there with:
Henh. I own the DNS server, so I put in 192.168.1.1 as the IP address for router.compusmiths.com, and when your machine resolves it, it goes out to that address, which is your local router. Neat little hack, but not very impressive at the end of the day.
Linksys and others could do the same, but note that it requires functional internet access to resolve the DNS, and most of the time you are doing the preliminary setup, and their tech support lines would be inundated with "why doesn't router.linksys.com work?"
My tech support line has been strangely silent on this subject. 8*)
"riggor99999" top-posted:
No, I have the DNS server on this. 8*)
