I wan't to disable the wireless On my linksys 80211b and g router. And anyone tell me the code, to get in the network? Thanks.
- posted
18 years ago
Go to the internet exployer and type in the IP that is in the manual.
"res0i39c" hath wroth:
It's usually on the "wireless" page in the web based setup. Not all wireless routers have a wireless disable feature.
If you want more specifics, kindly disclose the model number, hardware version, and firmware version.
192.168.1.1
user name: admin password: admin
If they don't work. Then you will have to push the reset button on the back of the unit.
*Warning* If you push the button to do a reset, all settings that were stored will be reset to factory.username - this is left blank on Linksys
Not on mine. I had to enter admin to get in. They may have changed it. Mine was old.
