Question about Cisco wireless AP VLAN
Dec 08, 2005 3 Replies
Jump to replies (3)
Hi all,
I have a question about Cisco wireless AP with VLAN and I hope someone can help me. We are using Cisco AP1200 with PEAP and ACS server. I know that Cisco AP can configure VLAN for different security level. Suppose I have this environments:
Wireless:
- SSID: SSID_Int
--- vlan 1
--- for internal staff
--- username: marketing01
--- access right: all internal network
- SSID: SSID_ext
--- vlan 2
--- for vendor
--- username: vendor01
--- access right: Internet only
All users accounts are stored in the ACS server. I suppose the user account "vendor01" can only access the AP using the SSID "SSID_ext". How about if the vendor change their SSID to "SSID_int" and use the "vendor01" account? Can it access the internal network? As I know, the ACS should not know the authentication request is from which vlan. If so, it will be very danger. Please advise. Thanks.
Regards, Dovelet
Dovelet schrieb:
You can use different RADIUS server for different SSIDs. You can tie a user to a list of allowed SSIDs
Thanks of your information. Different RADIUS server for different SSID is a solution but we do not want to maintain two RADIUS servers. For your second option, what is "tie a user to a list of allowed SSIDs"? Is it configured in the AP or the ACS server? Please advise. Thanks.
Regards, Murphy
Uli Link =E5=AF=AB=E9=81=93=EF=BC=9A
Dovelet schrieb:
It is configured in the RADIUS or the authentication database behind. Even the IOS embedded RADIUS can limit the allowed SSIDs per group. The same user/passwd will fail authentication associated through a not allowed SSID. Perhaps it is possible for you to setup your RADIUS to listen on 2 IP adresses. So if the APs request comes in via address A check for rule1, else check for rule2... For the AP this will be 2 different RADIUS and the RADIUS needs a criteria to differenciate between the requests, this can be an ip address or a subinterface/VLAN or the associated SSID. Whichever is easier for to setup/evaluated in your RADIUS setup.
