My WLAN led flashes at start up and that's it. I have tried both versions of the FW for this model and with the 1.33 the TX in the wireless section is blank and will not accept a setting. The LAN works but WLAN not.
I have not found the Italian D-Link dealer helpful and he points out that as the unit was bought in Germany it must go back there. In turn I have pointed out that both Nikon & Sony - Italy have honored warranties on items bought in other European countries.
I have wasted a lot of time (as you can see from my earlier postings) and am now waiting for another router which I found to arrive but I would like to know if my present one has a problem which can be resolved with software or is it just scrap?
Thanks in advance for any advice.
