Bookmark this page:
Yahoo!
Windows Live
del.icio.us
digg
Netscape
Posted by tg on July 8, 2008, 6:07 am
Please log in for more thread options mounted outside the house (size-wise it's like half a broomstick). My Windows XP PC showed 6 AP's in 'View Available Wireless Networks' , I got a couple of strong signals and the rest were weak. For comparison I then took down this antenna and put up a 15db omni antenna (bigger - 1.6meters long) in its place. What puzzles me is the 15db antenna picked up 12 AP's - which is double the previous antenna - but the signal of all AP's found was weak, not as strong as when using the 6dB. Is this normal behaviour for high gain antennas? What factors might cause this? poor wiring maybe? For the 15db antenna I use RG213 cable with N-connectors and for the 6db one I used ordinary TV coax with TNC. Cable length for both antennas is about 10 meters. Thanks for any pointers. | ||||||||||||||||
Posted by mlrodrig@gmail.com on July 12, 2008, 7:19 pm
Please log in for more thread options > I've been messing about with my wireless card and I was using a 6db omni =
antenna mounted
> outside the house (size-wise it's like half a broomstick). My Windows XP =
PC showed 6 AP's
> in 'View Available Wireless Networks' , I got a couple of strong signals =
and the rest were
> weak. For comparison I then took down this antenna and put up a 15db omni=
antenna
> (bigger - 1.6meters long) in its place. What puzzles me is the 15db anten=
na picked up 12
> AP's - which is double the previous antenna - but the signal of all AP's =
found was weak,
> not as strong as when using the 6dB. Is this normal behaviour for high ga=
in antennas? What
> factors might cause this? poor wiring maybe? For the 15db antenna I use R=
G213 cable with
> N-connectors and for the 6db one I used ordinary TV coax with TNC. Cable =
length for both
My theory is: It is all related to the meaning of "antenna gain". Why is it that one is said to have 6dB and the other 15dB? Think for a second... antennas does not have power plugs, so they don=B4t add power... how one can have more "energy" than the other? Here lies is the answer for your question. What an antenna with bigger gain does is concentrate the signal in a smaller area (or volume if you will, as it is 3D), so the area that is serviced get more signal (sacrificing other areas that will bet weaker signal). The same happens with reception, the bigger the gain, the smaller is the region it will do a good "listening". So an omni 15dB antenna only gets good signal from APs antennas that are on the same height as it. If the origin AP is slighter higher or lower (can be as little as few metters) it will get a weak signal. Your 15dB can hear far, but your neighbors APs (the first 6 ones) are not so well aligned with it, so the signal gets weaker. | ||||||||||||||||
Posted by Keith on July 18, 2008, 8:14 am
antenna mounted
showed 6 AP's
the rest were
antenna
picked up 12
was weak,
antennas? What
cable with
length for both
I am not an RF guru, but a little reading around suggests to me that a) you should definitely be using a 50 ohm coax like RG58 or your RG213 rather than standard 75 ohm TV drop cable, which has high frequency losses which are just way too high, and b) those cable runs are long - you can get signal attenuation well over 1 dB/meter at 2.4GHz, even with RG58 (I don't know about RG213, but it's probably a little better). I think the rule of thumb is to put the router as close to the antenna as possible, then run CAT5 from the router to where you need it. Compare these two articles, for instance: 1. http://en.wikipedia.org/wiki/RG-59 2. http://en.wikipedia.org/wiki/RG58 | ||||||||||||||||
| Similar Threads | Posted |
| confusion about wlan antennas | July 8, 2008, 6:07 am |
| Confusion about 108MBPS G? | December 27, 2004, 4:51 am |
| MA401/MA301 confusion | October 25, 2004, 11:45 pm |
| RP-SMA Male/Female confusion | July 4, 2005, 5:23 am |
| Wireless confusion! Too many options, help please | March 27, 2006, 9:27 am |
| WRT54G Linksys default antennas replace with 7 dbi antennas | May 9, 2005, 10:48 pm |
| Is there any way we would be able to detect which devices/laptops in a wlan are using 802.11b & which are using 802.11g cards? 802.11b clients in 802.11g wlan | September 18, 2005, 10:53 pm |
| Antennas | December 3, 2004, 10:12 pm |
| What are 2 antennas being used for? | July 24, 2006, 3:30 pm |
| Antennas | April 5, 2007, 12:26 am |
| I have some antennas, but..... | June 27, 2007, 5:43 pm |
| Can anyone use these external antennas? | April 25, 2005, 9:05 pm |
| Antennas & transceivers | February 26, 2006, 9:10 pm |
| Q: Biquad Antennas | July 15, 2006, 8:54 pm |
| comparing antennas | February 21, 2007, 7:20 pm |
Yahoo!
Windows Live
del.icio.us
digg
Netscape
