I just added a Ralink-based mini-PCI wireless card -- and small Hitachi antennas attached to MAIN & AUX antenna connectors on the card -- to a Compaq 2162US notebook PC. The antennas have about a 4" pigtail and they're easy to tuck under the door of the card. My problem...range is so-so and it doesn't stumble upon other WLANs in the neighborhood that it should see under normal conditions.
Question is, might this notebook have a pre-installed antenna with the cable end tucked away somewhere? If so, where might I look?
Fwiw...the notebook did not come with a pre-installed WLAN card. Thanks.
