I've noticed that every now and then, my connection speeds will drop drastically to 3 or 4 Mbps (normally it is a consistent 16 -17 Mbps). I talked to my ISP and we did some checking (by-passing the AEBS and connected directly to the DSL gateway) and I was getting a solid 20Mbps to the gateway. Power-cycling the AEBS corrected the problem. So.... is this normal or is it an indication that I'm headed for more future problems with the AEBS? BTW, I have both radios on because two of our laptops can use the 5GHz band but it's not really necessary if that could make a difference. Oh yeah, I've been thinking of using the
2.4GHz band only because dl speeds are usally 2Mbps faster. Thanks.- posted
13 years ago
