Comcast in PA Every Now and Then it Quits
Oct 09, 2004 2 Replies
I would say not much more than once a month the cable modem seems to loose contact with the server. I included the logand the signal strength from the cable modem's information page. Is thre anything blaring that could be wrong?
Downstream Channel The data shown in the table below provides information about the signal coming from the network to your cable modem. Lock Status Locked Modulation QAM64 Channel ID 1 Symbol rate 5056941 sym/sec Downstream Frequency 723000000 Hz Max Bit Rate 3300000 bps Downstream Power -0.73 dBmV SNR 33 dB
Upstream Channel The data shown in the table below provides information about the signal being transmitted to the network from your cable modem. Lock Status Locked Modulation QPSK Channel ID 2 Symbol rate 2560 ksym/sec Upstream Frequency 30992000 Hz Max Bit Rate 256000 bps Upstream Power 34.00 dBmV
Cable Modem The data shown in the table below provides information about the operational status of your cable modem. System Up Time 26Days 14hr:1min:31sec Network Access Allowed Cable Modem IP Address **.**.**.**
CPE Connections The data shown in the table below provides information about the customer premise equipment (CPE) connected to your cable modem. CPE MAC Address IP Address Connect To PC-1 00:**:**:**:**:** **.**.**.** Ethernet
2004-10-09 09:21:49 critical Started Unicast Maintenance Ranging - No Response received - T3 time-out
2004-10-08 20:23:47 critical Started Unicast Maintenance Ranging - No Response received - T3 time-out
2004-10-08 20:09:52 critical Started Unicast Maintenance Ranging - No Response received - T3 time-out
2004-10-08 20:02:49 critical Started Unicast Maintenance Ranging - No Response received - T3 time-out
2004-10-08 02:42:51 critical Started Unicast Maintenance Ranging - No Response received - T3 time-out
2004-10-07 20:38:36 critical Started Unicast Maintenance Ranging - No Response received - T3 time-out
2004-10-07 16:39:26 critical Started Unicast Maintenance Ranging - No Response received - T3 time-out
2004-10-07 05:54:16 critical Started Unicast Maintenance Ranging - No Response received - T3 time-out
2004-10-07 03:10:06 critical Started Unicast Maintenance Ranging - No Response received - T3 time-out
2004-10-07 01:48:43 critical Started Unicast Maintenance Ranging - No Response received - T3 time-out
2004-10-06 19:57:42 critical Started Unicast Maintenance Ranging - No Response received - T3 time-out
2004-10-06 19:42:19 critical Started Unicast Maintenance Ranging - No Response received - T3 time-out
2004-10-06 18:03:53 critical Started Unicast Maintenance Ranging - No Response received - T3 time-out
2004-10-06 18:03:52 critical Started Unicast Maintenance Ranging - No Response received - T3 time-out
2004-10-06 12:37:41 critical Started Unicast Maintenance Ranging - No Response received - T3 time-out
2004-10-06 00:44:40 critical Started Unicast Maintenance Ranging - No Response received - T3 time-out
2004-10-05 19:15:57 critical Started Unicast Maintenance Ranging - No Response received - T3 time-out
2004-10-05 19:14:17 critical Started Unicast Maintenance Ranging - No Response received - T3 time-out
2004-10-05 17:20:16 critical Started Unicast Maintenance Ranging - No Response received - T3 time-out
2004-10-05 01:46:06 critical Started Unicast Maintenance Ranging - No Response received - T3 time-out
2004-10-05 01:04:48 critical Started Unicast Maintenance Ranging - No Response received - T3 time-out
2004-10-05 00:01:14 critical Started Unicast Maintenance Ranging - No Response received - T3 time-out
2004-10-04 20:19:23 critical Started Unicast Maintenance Ranging - No Response received - T3 time-out
2004-10-04 13:53:17 critical Started Unicast Maintenance Ranging - No Response received - T3 time-out
2004-10-04 04:29:29 critical Started Unicast Maintenance Ranging - No Response received - T3 time-out
2004-10-03 21:11:17 critical Started Unicast Maintenance Ranging - No Response received - T3 time-out
2004-10-03 20:49:16 information DHCP: Syslog server not specified
2004-10-03 20:15:58 information Auth Comp MAC addr:** ** ** ** ** **
2004-10-03 13:31:20 critical Started Unicast Maintenance Ranging - No Response received - T3 time-out
2004-10-02 19:40:31 critical Started Unicast Maintenance Ranging - No Response received - T3 time-out
2004-10-01 15:35:31 critical Started Unicast Maintenance Ranging - No Response received - T3 time-out
2004-10-01 13:27:52 critical Started Unicast Maintenance Ranging - No Response received - T3 time-out
2004-09-30 22:25:44 critical Started Unicast Maintenance Ranging - No Response received - T3 time-out
2004-09-30 20:21:59 critical Started Unicast Maintenance Ranging - No Response received - T3 time-out
2004-09-30 13:28:28 critical Started Unicast Maintenance Ranging - No Response received - T3 time-out
2004-09-29 14:03:31 critical Started Unicast Maintenance Ranging - No Response received - T3 time-out
2004-09-29 12:54:19 critical Started Unicast Maintenance Ranging - No Response received - T3 time-out
2004-09-29 09:37:28 critical Started Unicast Maintenance Ranging - No Response received - T3 time-out
2004-09-29 08:43:03 critical Started Unicast Maintenance Ranging - No Response received - T3 time-out
2004-09-29 06:43:29 critical Started Unicast Maintenance Ranging - No Response received - T3 time-out
2004-09-29 06:20:39 critical Started Unicast Maintenance Ranging - No Response received - T3 time-out
2004-09-29 05:57:07 critical Started Unicast Maintenance Ranging - No Response received - T3 time-out
2004-09-29 03:25:40 critical Started Unicast Maintenance Ranging - No Response received - T3 time-out
2004-09-29 02:45:39 critical Started Unicast Maintenance Ranging - No Response received - T3 time-out
2004-09-29 01:11:10 critical Started Unicast Maintenance Ranging - No Response received - T3 time-out
2004-09-28 22:47:32 critical Started Unicast Maintenance Ranging - No Response received - T3 time-out
2004-09-28 21:07:36 critical Started Unicast Maintenance Ranging - No Response received - T3 time-out
2004-09-28 17:11:10 critical Started Unicast Maintenance Ranging - No Response received - T3 time-out
2004-09-28 13:05:37 critical Started Unicast Maintenance Ranging - No Response received - T3 time-out
2004-09-27 15:55:39 critical Started Unicast Maintenance Ranging - No Response received - T3 time-out
Its a lot less than once a week. Once every three weeks at the most. I know once time when we changed our cable TV sybscription, we lost cablt TV and internet for about 30 minutes while they reset the billing, again at 1am.
It interrupted my p0rn downloading...
