I want to add a couple outdoor PIR detectors and an outdoor IR Illuminator. The Crow PIRs are rated 8-16 VDC at a modest 8.4 mA, and the RayMAX Fusion
50 IR Illuminator is rated 12/24 V AC/DC at 25W. The PIRs will be used to trigger a camera and IR.Couple of quick questions.
- Would you recommend one power supply for everything, or would you use separate power supply for the illuminiator and if so why?
- Which power supply(s) would you recommend for this application?
Best, Christopher
