Can you link two motion sensor lights together wirelessly?
Threaded View
Anyone make motion sensor flood lights (I'm looking for two 1000W
lights) that can trip each other wirelessly, if either one of them
senses motion?
Re: Can you link two motion sensor lights together wirelessly?
The only way I can think to do that is using X10 outdoor motion/
floodlight devices.
You'd have to use them with a computer based automation controller
that had if/than capability because in any situation like this if you
tripped a second light with the first light ...... as soon as the
second light tripped it would turn on the first light in an endless
loop. The automation controller would allow you to program the "scene"
so that wouldn't happen. Also, I think those motion lights are only
good for 500watts.
If 1000 watts was essential, you'd have disconnect the exiting flood
light fixtures and use the motion light fixtures output to trip a
110VAC relay .... with that relay hooked to the 1000 watt lamp
fixture. Probably too elaborate a set up to be worth the effort.
Why don't you buy two regular lights, and control them both with separate
motion sensor(s).
"Newspaper claims car thief transformed into a goat"
http://news.yahoo.com/s/ap/20090124/ap_on_fe_st/odd_goat_thief_5
Site Timeline
