I have a closet light that the family is constantly forgetting to turn off. It is wired thru an X10 LM465 lamp module(G8).
I tried, and failed, to get Active Home 1.42 to automatically turn the light off 10 minutes after the on command. My thought was to have a macro trigger on the G8-on command and then send the G8-off command 10 minutes later. However AH will not accept both a macro and a device with the same house&unit code. I also couldn't figure out how to get one macro to trigger a different macro.
Anyone have a solution? Or am I attempting the impossible with AH? Is there a better controller program?
Oscar
