usb fm tuner input?
Jun 05, 2005 2 Replies
Eric Schuyler
Bill Kearney wrote in news:_umdnTFnoLo8cD_fRVn- Bill, Griffin Technology makes the Shark costs $70, which seems a little pricey, but it does use USB as you requested. Regards, Eric
usb fm tuner input? open original image
Hi all,
Anyone have recommendations for an FM tuner that uses USB and doesn't require using a sound card input? As in, not the D-Link unit. I'd prefer to have one that does the receiving and sends it's input directly as a digital stream, not one that provides a line-out that has to use a sound card port.
I don't "need" it to support TV input but if it's inexpensive I can just ignore those features.
Thanks,
-Bill Kearney
Bill Kearney wrote in news:_umdnTFnoLo8cD_fRVn- snipped-for-privacy@speakeasy.net:
Bill,
. It costs $70, which seems a little pricey, but it does use USB as you requested.
Regards, Eric
There is the WinTV-PVR USB2 which gets you TV, PVR, and FM all over USB2.
