macro apply ... $AVID
Oct 24, 2006 1 Replies
I want to apply cisco-desktop macro to all my access ports on my 4506
2/1 - 5/48
I tried int range gigabit 2/1 - 5/48 and does not recognize 5/48
Do I have to do this module by module?
Also if I go macro apply cisco-desktop ?
It is asking for this
c4506(config-if-range)#macro apply cisco-desktop ? WORD Keyword to replace with a value e.g. $AVID
what is $AVID?
It says in the doc that do not use vlan1. That is all I have one vlan (Vlan1)
the documentation explains this quite clearly:
er09186a00804fb28b.html#wp1974708
When you define a range, you must enter a space between the first port and the hyphen (-):
interface range gigabitethernet 5/1 -20, gigabitethernet4/5 -20.
Use these formats when entering the port-range:
=B7interface-type {mod}/{first-port} - {last-port}
Valid values for interface-type are as follows:
=B7FastEthernet
=B7GigabitEthernet
=B7Vlan vlan_id
You cannot specify both a macro and an interface range in the same command. After creating a macro, you can enter additional ranges. If you have already entered an interface range, the CLI does not allow you to enter a macro.
You can specify a single interface in the port-range value. This makes the command similar to the interface interface-number command. Examples
This example shows how to use the interface range command to interface to FE 5/18 - 20:
Switch(config)# interface range fastethernet 5/18 - 20
Switch(config-if)#
