IPTABLES help
Threaded View
Could someone tell me what this line, that's been added to my router
configuration at some stage, might be for:
iptables -t nat -I POSTROUTING -o <wan interface> eth1 -j SNAT --to <wan ip>
Thanks.
Brian Gregory (in the UK).
To email me please remove all the letter vee from my email address.
Re: IPTABLES help
Drat, of course I meant:
iptables -t nat -I POSTROUTING -o <wan interface> -j SNAT --to <wan ip>
Thanks.
Re: IPTABLES help
On Sun, 15 Nov 2015, in the Usenet newsgroup comp.security.firewalls, in article
Stuff happens  ;-)
http://www.netfilter.org/documentation/HOWTO/
   [TXT] NAT-HOWTO.txt 05-Oct-2012 10:33 25K
Section 6.1
   6.1.  Source NAT
  You want to do Source NAT; change the source address of connections to
  something different.  This is done in the POSTROUTING chain, just
  before it is finally sent out; this is an important detail, since it
  means that anything else on the Linux box itself (routing, packet
  filtering) will see the packet unchanged.  It also means that the `-o'
  (outgoing interface) option can be used.
  Source NAT is specified using `-j SNAT', and the `--to-source' option
  specifies an IP address, a range of IP addresses, and an optional port
  or range of ports (for UDP and TCP protocols only).
       ## Change source addresses to 1.2.3.4.
       # iptables -t nat -A POSTROUTING -o eth0 -j SNAT --to 1.2.3.4
The whole HOWTO is about 700 lines
        Old guy
Re: IPTABLES help
Thanks. I must try and read up on this stuff thoroughly some time.
I think I see why it might have been added, see my reply to 'Burkhard
Ott' below.
Re: IPTABLES help
All outgoing traffic is source natted with the IP of eth1.
Re: IPTABLES help
Didn't mean to type eth1 there, just <wan interface>. It's the WAN port.
I think it's actually ppp0, not eth1. Though eth1 is the PPPoE
connection going to be modem.
Is this perhaps making it so that all outgoing packets have the correct
from IP, so that I can't unwittingly be part of, say, a botnet that is
spoofing the source IP of outgoing packets?
Though I'm not sure that would work through NAT anyway.
Re: IPTABLES help
Well then it shoud be ppp0, you should see then a ppp0 interface too if
you do a ip a l.
What? If that would be a modification from malware, then you'd have a
much bigger problem, since these rules need to be set by root.
Why not? It's just IP.
cheers
Re: IPTABLES help
No.
I mean maybe that line was added by someone to make it impossible for us
to be part of a botnet, or whatever, that is sending packets with a
spoofed from address?
Re: IPTABLES help
That rule doesn't prevent you from participating in a bot net.  It
simply overrides the source address, making it so that you can't spoof
your source IP.  You can still participate in a bot net, just with your
real external IP.
Grant. . . .
unix || die
Re: IPTABLES help
That's what I said.
Re: IPTABLES help
 ip>
This makes your internet work in your internal network if you don't
have routable IP addresses for it.
Greetings
Marc
-------------------------------------- !! No courtesy copies, please !!
Marc Haber         |   " Questions are the         | Mailadresse im
Header
Mannheim, Germany  |     Beginning of Wisdom "     |
http://www.zugschlus.de/
Nordisch by Nature | Lt. Worf, TNG "Rightful Heir" | Fon: *49 621
72739834
Site Timeline
