Hi there,
I have a registered version of CISCO vpn client 4.6.00.0045. I just installed a new router @ home using NAT and firewall and connect wih ADSL. What rules should I add to the router to make an TCP/IPSEC connection to TCP port 10000 to the VPN SERVER (@work)
I need the correct settings so I can have a stable connection to the server. Somtimes the connection is lost or not connected a 100% (or so it seems). Or sometimes it seems that I cannot build a connection very soon after I close a session (maybe because ports are locked/or still in use?)
I have read on the internet that it might be the following ports, are these correct or do I need to add a couple more fore better connection?
NAT allow: from externel IF mer0 to local address 192.168.3.11 NAME PRO FROM TO LAN address VPN_10000 TCP 10000 10000 192.168.3.11 mer0 VPN_4500 UDP 4500 4500 192.168.3.11 mer0 VPN_62515 UDP 62515 62515 192.168.3.11 mer0
I really hope someone can come up with the correct settings. So far the internet is giving me different solutions and in it the meanwhile I cannot connect to my work place.
regards, Seansan
