Hi All, lately strange problem occures, i was unable to access (no telnet, no ping) one of our routers that have been running for about 2 years now without problems. After rebooting both router & connected Switch the problem is solved, but after that i have found that pinging the router from lan pc drop around 2% of the packets while invistigating the problem i have found that the reliablilty of the ethernet interface is varing from 195/255 to 238/255 !!. I tried to change both the ethernet cable & the connected switch but the same results.
Any Idea.
here is some informations :
Router#sh int eth 0/0 Ethernet0/0 is up, line protocol is up Hardware is AmdP2, address is 0007.85b1.efe0 (bia 0007.85b1.efe0) Internet address is a.b.c.d/x MTU 1500 bytes, BW 10000 Kbit, DLY 1000 usec, reliability 234/255, txload 11/255, rxload 11/255 Encapsulation ARPA, loopback not set Keepalive set (10 sec) ARP type: ARPA, ARP Timeout 04:00:00 Last input 00:00:00, output 00:00:00, output hang never Last clearing of "show interface" counters 01:47:42 Queueing strategy: fifo Output queue 0/40, 0 drops; input queue 0/75, 0 drops 5 minute input rate 466000 bits/sec, 521 packets/sec 5 minute output rate 449000 bits/sec, 131 packets/sec 3064844 packets input, 322288260 bytes, 0 no buffer Received 19406 broadcasts, 0 runts, 0 giants, 0 throttles 323513 input errors, 0 CRC, 0 frame, 0 overrun, 323512 ignored 0 input packets with dribble condition detected 1098027 packets output, 489124696 bytes, 0 underruns(20169/57317/0) 0 output errors, 77486 collisions, 0 interface resets 0 babbles, 0 late collision, 32229 deferred 0 lost carrier, 0 no carrier 0 output buffer failures, 0 output buffers swapped out
Router#sh ver Cisco Internetwork Operating System Software IOS (tm) C2600 Software (C2600-I-M), Version 12.2(2)T1, RELEASE SOFTWARE (fc2) TAC Support:
ROM: System Bootstrap, Version 11.3(2)XA4, RELEASE SOFTWARE (fc1)
Router uptime is 2 hours, 2 minutes System returned to ROM by power-on System image file is "flash:c2600-i-mz.122-2.T1"
cisco 2610 (MPC860) processor (revision 0x203) with 28672K/4096K bytes of memory . Processor board ID JAD05400A2X (221771976) M860 processor: part number 0, mask 49 Bridging software. X.25 software, Version 3.0.0.
1 Ethernet/IEEE 802.3 interface(s) 4 Serial(sync/async) network interface(s) 32K bytes of non-volatile configuration memory. 8192K bytes of processor board System flash (Read/Write)Configuration register is 0x2102
