Leased Line configuration on Serial Port (Cisco 1841)
Hi all,
Just wondering id some one is able to assit me with setting up 2 x Cisco 1841 To connect to a Leased Line connection. Details Listed Below.
Cisco 1841 Have Cisco IOS 12.1 - Also Have Serial Interface Cards Installed
Site A
Remote Site with a 2mb Leased Line connection IP Range 10.1.10.1 - 10.1.10.255 Ideally Would Like Router on IP 10.1.10.254 Need To connect to Site B for File / Exchange / DHCP
Site B
Main Site With 2mb Leased Line to Site A - Internet Connectivity Through Gateway 10.1.15.254 IP Range 10.1.1.1 - 10.1.9.254 DHCP 10.1.14.10 DNS 10.1.14.10 10.1.14.40
Looking for the best way to connect Site A to B with DHCP provided and internet through 10.1.15.254
Thanks
Master of Public Administratio
setup a gre tunnel between A and B add static routes on both routers to reach the LAN subnets through the tunnel confugure ip helper 10.1.14.10 on LAN interface of A configure DHCP pool on ROuter B for Router A's LAN subnet encrypt the tunnel after you get everything working
L J
I don't understand the reason for GRE tunnel LJ mentions, perhaps I'm not following what you want to do.
When you say you have a 2Mb leased line and your routers have serial interfaces, I'm assuming that means there is some sort of multiplexer that telco is providing you to bond multiple T1s? Or maybe you just use E1? At any rate the serial interfaces below may need more configuration specific to clocking and framing - but you don't provide particulars.
Its awfully tough to give you router config without understanding more of your SITEB setup, but in general ROUTERA is awfully simple to set up. It doesn't sound like you have a routing protocol running so we'll just use a static
ROUTERA:
interface serial 0/0 description LINK_TO_ROUTERB_2Mb ip address 10.50.1.1 255.255.255.252
interface fastethernet 0/0 ip address 10.1.10.254 255.255.255.0 ip helper-address 10.1.14.10 (sounds like 10.1.14.10 is a MS DHCP server of some variety?)
ip route 0.0.0.0 0.0.0.0 10.50.1.2
ROUTERB:
interface serial 0/0 description LINK_TO_ROUTERA_2Mb ip address 10.50.1.2 255.255.255.252
interface fastethernet 0/0 description This might not be how your network is laid out, so the default route below might not make sense if this particular router doesnt have an interface on 10.1.15.x ip address 10.1.15.x
ip route 0.0.0.0 0.0.0.0 10.1.15.254
jseemann
