I just can't get this to work out of the box/running wizard. I'm getting error on client of:
Secure VPN Connection terminated locally by the Client. Reason 412: The remote peer is no longer responding.
What areas should I be looking at please? I've set the VPN Easy Server up and made it Initiate as well as Respond. I'm using a key phrase to connect with. I've tested the VPN server in the SDM software and its says its ok.
Short of an entire dump please let me know what more info you need?
