Bookmark this page:
Yahoo!
Windows Live
del.icio.us
digg
Netscape
Posted by on April 15, 2006, 4:50 pm
Please log in for more thread options Hi I'm looking for a good (and long lasting) way to label 4 wire flat telephone cables (I don't know the technical name of the cable). I tried using p-touch labels, but they came off. I also tried using MityMark ZT wire marking system, but they also peeled off pretty quickly. Can any one recommend a solution that will hold? TIA Paolo | |||||||||||||||||||||||||||||||
Posted by Robert Redelmeier on April 15, 2006, 7:39 pm
Please log in for more thread options vrkid0@gmail.com wrote in part: Silver satin. > tried using p-touch labels, but they came off. I also tried
> using MityMark ZT wire marking system, but they also peeled off > pretty quickly. Can any one recommend a solution that will hold? Clear shrink wrap over toner-printed paper. Easiest to put on before the RJ is crimped on. -- Robert | |||||||||||||||||||||||||||||||
Posted by Bob Vaughan on April 16, 2006, 4:30 am
>> telephone cables (I don't know the technical name of the cable). I >
>Silver satin. > >> tried using p-touch labels, but they came off. I also tried
>> using MityMark ZT wire marking system, but they also peeled off >> pretty quickly. Can any one recommend a solution that will hold? >
>Clear shrink wrap over toner-printed paper. Easiest to put on >before the RJ is crimped on. > Agreed, except I use P-touch labels, with heatshrink. they tend to stay put, while paper tends to wander. Also check out Brady labels.. -- -- Welcome My Son, Welcome To The Machine -- Bob Vaughan | techie @ tantivy.net | | P.O. Box 19792, Stanford, Ca 94309 | -- I am Me, I am only Me, And no one else is Me, What could be simpler? -- | |||||||||||||||||||||||||||||||
Posted by Al Dykes on April 16, 2006, 9:23 am
>>> telephone cables (I don't know the technical name of the cable). I >>
>>Silver satin. >> >>> tried using p-touch labels, but they came off. I also tried
>>> using MityMark ZT wire marking system, but they also peeled off >>> pretty quickly. Can any one recommend a solution that will hold? >>
>>Clear shrink wrap over toner-printed paper. Easiest to put on >>before the RJ is crimped on. >> >
Panduit makes all sorts of mylar stick-on labels for this purpose. I've used the laser printer sheets and made up sequences batches of numbers and pealed themm off as needed. The're perfect. The major problem is that the last time I looked the smallest package they sold was almost 100 bucks. http://www.panduit.com/ They send me a sample of a page each of several types sent to my company address. -- a d y k e s @ p a n i x . c o m Don't blame me. I voted for Gore. | |||||||||||||||||||||||||||||||
Posted by Jgolan on April 16, 2006, 2:51 pm
Brady as well as others have a self-laminating label that is Laser Printable (The LAT series and the clear portion protectes the printed portion. Very easy to put install and come in various sizes (width and length). Problem is that the minimum quantity of 1000 label package which was mentioned by another replyer. If you have a sequence and know what you need in advance, I can provide this at a minimal cost over the blank labels (my minimum is by a full sheet). If you need this service please email at jpgolan-rcdd@earthlink.com and we can pick up on the details off the forum. I also can proiduce labels for your patch panels, blocks, outlets, etc. All professionally done (Laser-jet or Thermal xfer printing). I can use you database or provide services as needed at hourly rate. All typical jobs get a 48 hour turn around but 24-hour is possible. I have 1000s of labels in stock (including some in color backgrounds for EIA/TIA requirements). I can also produce cusome labels for any special needs you have. Your other option is to use special hand-held printers for the onesy-twosy need, again Brady as well as others can help you with these product and also have the self-laminating label stock. J Golan, RCDD ------------------------------------- vrkid0@gmail.com wrote: > Hi
> I'm looking for a good (and long lasting) way to label 4 wire flat > telephone cables (I don't know the technical name of the cable). I > tried using p-touch labels, but they came off. I also tried using > MityMark ZT wire marking system, but they also peeled off pretty > quickly. > Can any one recommend a solution that will hold? > TIA
> Paolo -- ##-----------------------------------------------## Article posted with Cabling-Design.com Newsgroup Archive http://www.cabling-design.com/forums no-spam Web and RSS interface to your favorite newsgroup - comp.dcom.cabling - 2492 messages and counting! ##-----------------------------------------------## | |||||||||||||||||||||||||||||||
| Similar Threads | Posted |
| cabling labels | April 15, 2006, 4:50 pm |
| labels | May 4, 2006, 6:03 pm |
| panduit labels | May 23, 2006, 7:44 pm |
| Ethernet cabling used outside | July 29, 2004, 7:57 pm |
| LSZH Cabling | August 3, 2004, 10:11 pm |
| Help with telephone cabling | September 26, 2004, 4:10 pm |
| cabling jammed together | October 12, 2004, 10:50 pm |
| Cabling length | December 1, 2005, 4:47 am |
| Cabling Forums | February 13, 2006, 9:58 am |
| Need some pointers on my first cabling job | March 25, 2008, 7:39 am |
| cabling for colorblind people? | July 9, 2004, 11:10 pm |
| Data Communications Cabling FAQ | October 29, 2004, 7:24 am |
| Data Communications Cabling FAQ | July 29, 2004, 7:17 am |
| newbie cabling question | August 24, 2004, 3:17 pm |
| Data Communications Cabling FAQ | August 29, 2004, 7:28 am |
cabling labels
Yahoo!
Windows Live
del.icio.us
digg
Netscape
