Telephone extensions
Aug 25, 2005 4 Replies
I want to convert my second phone line that I use for dial-up to an extension on my first phone line, which I will be getting DSL on. Will it work if, after cancelling service for the 2nd phone line, I take the wires off the screws they're on in the NID and put them on the same screws as those for the first phone line, matching the colors? Will my
2nd phone line jack then become an extension on my first line?
Thanks.
It should work, but it's not a good idea. You don't want the line that your DSL is on connected to a million places throughout your house. Not only will it degrade the quality of your DSL connection but it will mean that you'll need a filter on every single telephone device.
DS
Isn't having DSL on the same line as your voice service and having a filter on everything the standard configuration?
If by standard you mean the cheapest way that might work, then yes. If by standard, you mean recommended, then no, at least, not by anyone I know of. The recommended way to do is by putting a splitter as close to where the line enters your premises as possible.
DS
Yes, that will work just fine. If you have more than somewhere around
5 phones total, some of them may have trouble ringing, and you'll want to ensure you have filters on all the phones on all your lines (or install a whole-house splitter), but essentially what you want is pretty straightforward.
