Zyxel 660HW Wireless DHCP problems
Sep 07, 2005 0 Replies
I've a problem when connecting to my accesspoint (Zyxel 660HW). It doesn't relay DHCP or even traffic.
Situation: Modem/Router/Accesspoint/Switch (Zyxel 660HW) is connected to Internet, DHCP is off, Windows 2003-server (Small Business 2003 SP1) is connected through the switch and running DHCP. Wired it's all runnin great. Wireless I get connected to the Accesspoint and that's it, no DHCP. There even is no traffic between pc/laptop and accesspoint. Even when I make a static ip, it doesn't work.
I've contacted Zyxel and they told me to telnet and change a general setting Bridge to On. So I did, it doesn't work. I've looked further and discovered that multicast was off. For my knowledge DHCP-requests are multicast (right?). I put in on. No result. Of course I've tried everything else; DHCP-Relay on/off, firewall on/off, wirelless standard settings (no WEP/WPA).
Anyone else?? I would very much appreciate it.
Georgie
