No. The router will share the connection. It Depends. With a good signal, your wirelesss connection is manytimes faster than your internet connection, so you are unlikely to notice the difference between wired and wireless. If signal is very poor, it may ne slower. Set up the…
Hi all,Hi all,I have just re-built an old PC to create "Server" for my Home...
C
Chris Bartram
Set up the router as per the manual. The DG834 is easy. Make sure you enable some encryption- WEP or WPA. Install the wireless card as per the manual. If you have XP SP2, that will pretty much lead you through the setup at the PC.
D
Duane Arnold
"Craig" wrote in news:4229d5a1$0$10946$ snipped-for-privacy@news-text.dial.pipex.com:
If you understand how a NAT router functions a wired or wire/wireless NAT router, then you would know that the router is the gateway device for the WAN (Wide Area Network)/Internet and no computer connected to the NAT router wired or wireless connection needs ICS enabled by the computer's O/S to access the Internet, because of the NAT router being the gateway device.
The other function of the gateway router is the allow connection sharing, resource sharing or file sharing between computers on the LAN (Local Area Network), which includes machines connected wire to wire, wireless to wireless and wire to wireless.
Most likely, you'll notice a speed difference between wire connection and a wireless connection.
You should get on the phone with Netgear Tech Support. If they cannot do anything else, they should be able to walk you through a wireless setup.
Duane :)
Report Content
ASAP.
