ICS problem on WiFi
Aug 29, 2005 0 Replies
Hi all,
Hi all,
I have just re-built an old PC to create "Server" for my Home Network. It is running Windows 2000 Pro. As I am still setting it up, and not currently in the position to move it to the same room as the Router due to room shifting, I want to use ICS from "New Laptop" to connect it to the Web and update it. The laptop is running Windows XP Home on a WiFi network, and the wireless connection is shared. I followed the ICS setup instructions on PracticallyNetworked.com, but it still will not work. I have tried it on 2 different Network cards, without any luck.
Can anyone shed any light on the subject?
If I have missed any info, just say,
Cheers,
Neil
