XP ad-hoc wireless network : How to change channel?
Feb 09, 2006 6 Replies
Neill Massello
Create a new computer-to-computer (ad hoc) network that uses a different channel and switch all your machines over to it.
My network is a computer-to-computer one, using the XP automatic wireless configuration. I see that the computers connect on channel 11. There's someone in my neighborhood who now has a wireless router on channel 11 too...
Is there a way to configure XP wireless so it uses a different channel?
neilsanner
Hi Neill,
When I to in "Wireless Network Connection Properties"> Wireless Networks> Preferred Networks> Add, there's no option to specify a channel...
neilsanner
Neill Massello wrote:
First add the network, then configure it.
Start > Control Panel > Network Connections > Wireless Network Connection > Properties > Configure
There should be an option to select the channel, at least I see that option!
"Configure" on the "General" tab of the "Wireless Network Connection Properties" brings me to the my Wi-Fi card properties. Is this what you meant by "Configure"? There's no options there to change the channel.
neilsanner
SMS wrote:
Yes. On mine, when I click on "Configure" next to "Intel (R) Pro Wireless 2200BG..." it brings up another dialog box with a list of properties. The first one is "Ad Hoc Channel" and next to that is a drop-down box where you can select 1 of 11 channels.
Ok,
Then it depends on the adapter and the driver. For my card (WLAN a+b+g mini-PCI Module; Atheros chipset), there's no such option. The only workaround I could find is to use the manufacturer's utility that comes with the card. Mine is called "Atheros Configuration Utility". I prefer to use the Windows to configure the wireless network settings but since it doesn't allow for the channel selection, I guess I'll have to forget about it.
neilsanner
SMS wrote:
