Is there any such thing as a wireless USB port? I need to hook up a USB device (a webcam pointed at a fishtank) that is a hundred feet from the computer and router. What would be a good way to do this?
Wireless USB port?
Nov 06, 2004
The camera might be an issue - I have two webcams, but I don't have $$ to get another camera, I was hoping there was some way to use the USB camera :(
Read the full replyThe camera might be an issue - I have two webcams, but I don't have $$ to get another camera, I was hoping there was some way to use the USB camera :(
Also try the USB product search at:
Optical:
Active:
There are others...
On Sat, 6 Nov 2004 15:21:44 -0800, Ook spoketh
There is no good way of doing this. The camera needs to be connected to a computer to work, so unless you have a laptop handy, that camera isn't going to get the job done. There are wireless 802.11b cameras available that might be a better solution...
Lars M. Hansen
'badnews' with 'news' in e-mail address)
There's probably much better ways, but you could pick up a cheap TV tuner card (I got one at Aldi for $69), then use a transmitting camera, or a video sender, and connect the receiver into the TV in card.
Adam
