Wireless Multimedia (WMM) question
Jul 27, 2007 2 Replies
When using WMM-certified network cards, will all my audio/video applications get automatically higher priority in the network or these applications have to support WMM? If for using the advantages of WMM, the multimedia applications have to be WMM-aware, do you know any information about what audio/video applications currently support WMM?
Thank you very much!! Alex.
qnx escribió:
Hi Alex,
that's a good question. I really don't know the exact answer but 802.11x is a Link Layer protocol and Link Layer software talks with Network layer one.
With that premise, Network Layer software should insert traffic in the proper queue to make use of QoS capabilities of WMM-certified hardware in function of its origin (or traffic class).
By the same rule, applications should notify Network Layer software (or whatever intermediate layer) what class of traffic is trying to send.
I don't know if intermediate layers made a mapping of traffic or application must explicityly notify it.
I guess somebody can help us with this excellent question.
Best regards.
qnx hath wroth:
The QoS (Quality of Service) part is right out of 802.11e. Very crudely, it assigns a priority to various protocols, ports, apps, or whatever. It crams the highest priority packets into the contention interval between low prioirty packets.
What you're really asking is how these priorities are assigned. It's NOT automagic. The router is not expected to be able to detect and distinguish various applications as they dribble through. You have to do it manually in the router.
For example, the QoS/WMM support on the Linksys WRV200 is rather minimal and crude. See the settings at:
You pick a port number that is used by the application, and assign it a priority. There are really 16 levels of priority, but Linksys only offers 2.
A more complete implimentation is WMM on DD-WRT:
Noticed that there are no settings for the name or type of application. Just "audio" and "video". This is strictly for setting how the QoS system works. The actual priority for a given application gets set on the QoS page such as:
(Check "Enable QoS" and click on the Services Priority -> Add/Edit Service button. Note that you have to specify the port numbers. Some details and sample settings:
Note that Wireless QoS is different from LAN QoS.
However, there is enough commonality that most routers just mix them both together on the same settings page. Oh well.
QoS and WMM can also be implimented in the client operating system. See:
WiFi QoS in Windoze Vista (4 parts):
Microsoft QoS pages:
