Hotspot Connection question
Jul 27, 2007 1 Replies
I'm trying to connect to a local free hotspot with my desktop using a roof mounted directional antenna connected to a Linksys WRT54GS (with DD-WRT firmware installed) to act as an AP Client. Can I run thr Cat5E directly into the LAN connection on the desktop or do I need to go through the WAN connection of a second router.
Both the FREE hotspot and your wireless Access point should support birdging first, then you can route a UTP cable to your desktop or notebook LAN to have multiple computers talking to the Hotspot.
Panda,
