Wireless drops after enabeling WEP Security
Nov 25, 2004 6 Replies
Jump to replies (6)
On the 2 computers running Win 98SE the connection to the AP drops them randomly every 18 to 36 hours.
I have a D-Link NIC in both computers one is a DWL-G659 and the other is a DWL-G520. My AP id a D-Link DI-624. This did not happen prior to enabling security features. I have WEP on an open key.
I have to reboot the AP to resolve the problem from a wired computer.
18 to 36 hours sounds pretty good. Do you mean the connection is active for 18 to 36 hours then drops? With the extra computing power to encode and decode wep, they may be dropping due to heat exhaustion.
The network or home network disconnects and thus so does the internet. The NIC cards are cool enough and the AP is never even warm. I can't imagine the WEP encryption would heat up the cards as it is software driven.
The heat exaustion was just a pun, but there are APs that use software to encrypt/decrypt (usually the least expensive) and there are those that use hardware. Some even add an extra processor to do the work. More processor cycles = more heat. Some cards have built in heat detection and turn themselves off, or they notify the OS which turns them off. So even a pun is possible.
computer.
connection
almost
That is certainly not a universal feature of WEP. My WEP'd connection (based on different hardware from yours) is very stable, frequently good for over a week. I do reboot the laptop every week or two, but almost never due to loss of wireless connection.
Do they both drop at the same time? If so, this (and the temporary workaround of rebooting the AP) woud tend to indicate that the problem is in the AP. I assume it's at the latest firmware. You might try a factory reset and reloading all your values, it's possible something got set improperly. You might try asking D-Link, though they'll almost certainly not have an answer, or try another AP.
No they drop at different times, it even effects the wired computers. Jim
