wireless adsl router
Feb 09, 2006 2 Replies
looking to buy a wireless adsl router with modem built in can anyone recommend one thanks
GT704-WG ActionTec It works.
I'd reccomend separate products, when you switch your broadband to a different physical medium (WWAN, cable, fiber, whatever) you'll be unable to reuse the router section of your combo box.
In fact, since you can't configure, diagnose, or repair the DSL modem, I reccomend you rent it from the telco, as it eliminates finger pointing if something goes wrong.
