Win2k trouble with Linksys WUSB54GS Wireless-G USB Network Adapter with Speedbooster
Feb 21, 2006 0 Replies
We have been unable to get this to work properly on a Windows 2000 Professional Desktop Computer running Windows 2000 Service Pack 4
Local environment is a Linksys G Wireless Router Linksys wireless utility sees and connects immediately to the Wireless router
20 feet away with excellent signal strength. Windows does not obtain an IP address (DHCP) When a LAN cable is connected, IP is obtained immediately
Spent several hours on phone troubleshooting with Linksys Tech Support.
Installed latest firmware updates for router Unintalled and reinstalled adapter several times
For adapter drivers, we are using the latest downloadable executable that extracts to the folder WUSB54GSv1_20050428
WUSB54GS.inf has the following text: ; Windows 2000 specific sections ---------------------------------
[RNDIS.NT] Characteristics = 0x84 ; NCF_PHYSICAL + NCF_HAS_UI BusType = 15 DriverVer = 08/09/2004,5.1.3538.0 AddReg = RNDIS_AddReg_NT, RNDIS_AddReg_Common,ABer.reg CopyFiles = RNDIS_CopyFiles_NT
Have tested with and without WPA. Have tested with security completely disabled. Have deleted Win2k TCPIP protocol Have rebooted and reinstalled TCPIP protocol Have uninstalled and reinstalled latest Linksys drivers many times
Have tested this adapter successfully on other XP and 2000 SP4 machines. Have tested in local environment on XP PC with existing Linksys G router and in other environment on Win2k Professional with Belkin pre-N router. Works first time, every time.
Does not obtain an IP address on problem Win2k Desktop. Adapter eventually gets a 169.xxx.xxx.xxx automatic IP address Tried assigning a static 192.168.x.x IP address but still unable to ping router, even with strong signal strength. Linksys wireless utility reports adapter is connected to wireless access point, but not to internet.
This has been going on for 3 weeks and not sure what else to check.
Help!
