Wifi-Radar Question
Apr 12, 2007 0 Replies
I've got Wifi-Radar loaded on a Umbutu Edgy laptop. And it works fine. I'd like it to work Great!
The problem. Yes there are people that don't use 'decent' SSIDs. And of course they are not going to change them just for me. Saving a configuration for someone that uses 'wireless', or 'linksys', etc will overwrite others with the same SSID. The configuration file /etc/wifi-radar.conf uses the SSID as the 'configuration section' (my term).
I'm looking for a way to use [my generated name] and then have the SSID in further down: something like
[Dons Place] ssid = linksys
