UPNP with wireless?
Feb 06, 2007 1 Replies
John Navas
UPnP will work on wireless as well as wired. The likely problem is that the ports you want were/are still reserved for your wired IP address, and you're getting a different IP address on wireless. Either use the same IP address on wireless, or hard reset the router to start…
With my BitTorrent client I can automatically have the routing setup with my router using upnp when connected to the network with a LAN connection. If I use my wireless card on the same computer, it doesn't auto-configure. Any idea why this is? Is it just supported on LAN connections? Using a D-Link GameFuel router.
Thanks.
JR
On 6 Feb 2007 14:27:17 -0800, "JR" wrote in :
UPnP will work on wireless as well as wired. The likely problem is that the ports you want were/are still reserved for your wired IP address, and you're getting a different IP address on wireless. Either use the same IP address on wireless, or hard reset the router to start over with UPnP on the wireless IP address.
