terminology question
Jan 30, 2006 4 Replies
Jump to replies (4)
terminology question open original image
I am wanting to ascertain whether I can use my router in a particular way, however I have found it difficult to do a search because I unfamiliar with some WiFi terminology.
I am interesting in relaying wi-fi to wi-fi signals.
=== wired connection ... wi-fi connection
Among the many ways to relay a wi-fi signal I am interested in two in particular.
It seems possible that a computer with two wi-fi NIC's could do it even if a single router could not. I read a web page where someone did something similar to METHOD 2 using two Linksys routers in place of Router2.
Using the following text-diagram (fixed with font required)
Internet ===== Router1 ......... Router2 ......Comp3 . . . . Comp1 Comp2
METHOD 1: In this mode when comp2 or comp3 requested an IP, Router2 would pass the request over to Router1, then Router1 would assign the IP for Comp2 and Comp3. From then on Packets packets going ether way between the Internet and Comp2 Comp3 would pass through Router2 and Router2.
METHOD 2: Router2 uses NAT. When Router2 is first turned on it request an IP from Router1. When Comp2 or Comp3 make a request for an IP# it is assigned a number by router2. From then on when Comp2 or Comp3 make a request for data Router1 sends treated that data as if it were destined to router2. It is Router2 that determines whether the data goes to Comp2 or Comp3
I'm not sure if these types of wi-fi to wi-fi bridging have a name or not. From what I've read it seams that WDS is not exactly the same as method 1, because WDS use a vendor specific protocol is usually not work when Router1 and Router2 have different manufactures. In METHOD 1 I would prefer to use standard IP protocol or tunneling.
PS. in case anyone is interested, I will be placing the router in the house owned/build by my roommates fiancee who is the father of the person of the Internet connection. They don't want a lot of wires running around the house.
this is a realy easy thing to do ,but you didn't tell us the model of the router! if it is a linksys wrt54g or gs you will have no problem as long as it is not a ver 5. if it is a wrt54g or gs you can email me i will help you step by step (even if ya only buy one wrt54g or use another cheaper ap i could help ya. walmart sells the thing for 49 bucks ya can't go wrong! before ya go shopping though d/l the list of serial number that way ya don't end up with a ver 5
Question 1: Is there a name for these type of relaying of WiFi signals?
Question 2: In my particular case Router1 is am ISP supplied SMC router, that Michale does not want to change out. Router2 in my router that is a Linksys wrt54g v5 that I am willing to get alternative firmware for. Can I do it with the standard firmware? Do I need to get an alternative firmware for this router?
What you want to do is to connect two physical networks. That function (or "layer") is separate from IP routing. Most wireless base stations now include built-in routing functions and are designated as "wireless routers" to distinguish them from the "wireless access points" that don't perform NAT. As far as linking Router1 and Router2 wirelessly, it doesn't really matter whether one or both or neither is doing NAT.
To have the two boxes communicate wirelessly, either Router2 has to function as a client on Router1's wireless network or Router1 and Router2 have to do WDS with each other. Using Router2 as a wireless access point for Comp2 and Comp3 rules out its use as a wireless client of Router1. At least I don't know of any consumer box that can operate in client and infrastructure (or base station) modes simultaneously. You'll either have to use WDS or add a third device (between Router1 and Router2 in your topology) that would connect to Router2 by wire and to Router1 as a wireless client.
If you don't need to grandfather any existing wireless hardware into this system, it would be much easier to get a pair of WDS-capable routers and turning off the NAT and DHCP functions on the box in the Router2 postion.
  1. Setting up WDS
    is where a second router wirelessly extends the range of the first. (Th elink refers to my successful attempt at setting WDS up.)
  1. v5 WRT54G routers can't be flashed (at present?) as, unlike their predecessors, they do not run firmware under Linux.
