system standby failed
Nov 06, 2004 2 Replies
On occasion, when I set down my Dell laptop screen to put the system into standby mode, it fails to enter standby mode and produces the following error instead:
. Any ideas on how to fix this would be greatly appreciated. -Emmett
maybe you have a live connection somewhere, an image refresh or something renewing itself every x seconds - the wifi card has to have no active connections to enter standby . might load a network monitor program which should show you what the connection IP is and you'll figure it out from there.
presumably the network card is still busy. Wait a few seconds, and try again. Alternatively upgrade the driver as the error implies.
