Locked out of Scantronic 9827 Control Panel
Apr 08, 2006 4 Replies
Jump to replies (4)
Folks,
I was attempting to change the time on my 9827 control panel by keying in the access code + 3 (I think). Instead of displaying YY in the two digit display as I expected, it's displayed two lines, the typical display when another command is to be input.
Unfortunately every key I press now just produces a buzzing tone and nothing seems to put it back into its standby mode (or whatever mode it is when it's doing nothing).
Any tips?
Evan
Try 99 then Clear (tick) Or 7 then Clear (tick)
If you want I can get you the manuals.
Thanks... I will try this.
We've actually got the user and installation manuals. Neither have a troubleshooting section or describe this problem.
They do menti> Try 99 then Clear (tick)
If your confident about programming it again, I would do a cold restart and start again.
