Reverse Engineering Wireless Network
Sep 14, 2007 2 Replies
Hey All: This year in the dorms they have decided to create a wireless network to send out internet. Unfortunately, that means a lot of issues for me with drivers for wireless pci cards in my desktop, etc. I have a Linksys WRT-54GS router. I have heard it is possible to reverse-engineer the router so that it will receive the wireless signal itself, and transmit it through its own ethernet ports into my computer. Does anybody know how to do this? I am open to installing alternate custom firmwares etc. Thanks for any help, and I can respond with any more info needed!
--Databoy2k
If they have opted for wireless instead of hardwire, then they should give you all the assistance you need in configuring your access.
The internet does not do take out, send out, or deliveries.
Yep. If it were easy, it would be no fun.
Yeah, something like that. What I'm guessing you're trying to accomplish is use the WRT54G as either a wireless client ethernet bridge, or a repeater.
See:
or:
You'll need to verify that the hardware version of your WRT54GS is suitable for running alternative firmware. If it's V5, 6, 7, or 8, forget it. Check the serial number sticker for the hardware version.
