Question of Compatibility
Jan 06, 2005 1 Replies
Running Linksys Wireless B Broadband Router w/ Linksys Wireklss-B Adapter on my laptop w/ Win XP SP2.
Can I run a wireless-g adapter on my notebook with the B router, or do I need to replaceboth Linksys with "G" stuff? Trying to increase my range/intermittent connections.
Thanks!
RED
The G will connect to the B router but at B speed. It may not increase your range unless your current B card is going south. If something external is causing interference and causing your intermittent connections then it probably wont help that either. But if you think you might upgrade to a wireless G router later then Id go with the G.
