Wireless Question
Jan 04, 2005 1 Replies
Presently have MN 500 wireless "B" router, with notebook MN 520.
Planning on upgrading to wireless "G" MN router and notebook adapter.
Is it worth it??
I am having problems with the MS SP2, by upgrading to the MN "G", will this take care of the problem. Thanks
Taking a moment's reflection, Rene Anobis mused: | | Presently have MN 500 wireless "B" router, with notebook MN 520. | Planning on upgrading to wireless "G" MN router and notebook adapter. | Is it worth it??
If your B equipment does not support WPA, which it most likely does not, then (to me) that would be reason enough to upgrade.
| I am having problems with the MS SP2, by upgrading to | the MN "G", will this take care of the problem.
Possibly. But, difficult to say for certain without knowing what the problems are.
