Problems With DLINK DWL-700AP
May 09, 2005 0 Replies
I have a DLINK DWL 700-ap and am having trouble using it as a wireless client
I have successfully connected via the wired link to a port on my wireless router and set it as a wireless client
my ip setup is on 192.168.1.xxx the router is 192.168.1.254
the dlink wireless ap is set to 192.168.1.50
if i connect the ap to my pc that i want to use a s the wireless connection, i can connect to the ap but not to the router (or therefore, the net)
what do i need to set up as my tcp/ip settings to connect to the router?
The router is WEP encrypted and as far as i know i have set the connection correctly via the control panel for the access point
any help would be gratefully appreciated
craig
