Netgear WGR614 needs "reboot" periodically (needs power cycle)
Feb 22, 2007 6 Replies
Jump to replies (6)
I have a Netgear WGR614 wireless router and recently I lose sight of it a couple of times a day. That is to say, either my SSID disappears from my available networks list or, if it's listed, I cannot connect. The only solution I've found so far is to walk up to the router, and "power cycle it"--i.e. unplug it, wait and replug the power cord.
I've tried doing a full reset by holding in the reset button but it still goes AWOL.
any suggestions?
(I know routers are cheap and it is probably easier to just replace it.) Many thanks
Hi, thanks Sorry, should have mentioned, the firmware is the most recent version (v7) so I didn't reinstall it. would there be any value in reinstalling it anyway, to get a fresh install, even though there is no functionality improvement?
Peter
i dont think there is a version 7 firmware update. are you refering to Netgear WGR614 v7?? try again using the router login site to upgrade.
Here's the ROuter STatus info off the Setup Utility.
Account Name WGR614v4 Firmware Version V5.0_07
ahh, I guess it is Version 5.0. Sorry. you are correct (I saw that 07 tagged on the end there.)
nonetheless, checking the Netgear download page, this is still the most recent version of the firmware.
ahh, I guess it is Version 5.0. Sorry. you are corect (I saw that 07 tagged on the end there.)
