Need help configuring netgear wgps606 wireless printer
May 01, 2006 1 Replies
I have a wireless network and want to add a wireless print server to the existing network. Here is my current configuration:
DSL modem connected to a wireless router. All works fine. The problem is that I have printers that are located about 30 feet from the modem and the wireless router. So I bought a wireless router/printer. The problem is how do I connect the wireless/printer router to the network next to the printers. I don't want to run cabling between the 2 routers. Someone mentioned I should have purchasd an access point rather a router but I don't have many choice. Does anybody have any suggestions.
What you want is a "wireless printer server" (separate box), not a wireless router that's also a printer server. Make sure to get one that's compatible with your printer(s).
