Motorola SBG900 admin problem
Jan 28, 2006 3 Replies
Jump to replies (3)
I'm hoping someone can shed some light on a problem I get while changing settings in the modem. I log in to the modem as admin, and when I try to make a change in any screen, in this case it was port forwarding, I instantly get bounced back to the login screen. I suspect my browser, IE6, XP service pack 2, all the latest security updates, but have nothing more to go on, I have flushed temporary files and history, to no avail.
Thanks in advance for any help
Gene Puhl wrote in news:Xns975995D832BC6Vizor347@61.9.191.5:
are the settings still being saved? some routers need to reboot if you change anything reguarding the port forwarding or routing table.
smowk had me ROTFL with: news:Xns9759A854D52BEsmowkyahoocom@216.196.97.131:
As soon as I hit "ADD" after entering the settings, IE clicks about 3 times and flashes and I'm back at the login screen, so I have no idea, but, going back to the port forwarding screen, everything is as it was before.
TIA
try opera, or firefox...IE tends to do weird things sometimes...
