Linksys 802.11b
Oct 17, 2005 1 Replies
Your network will work the same. You can leave the router wireless setting at "mixed" or "b only". However I believe that if you get a g adapter and have the b wireless receiver on the network will set itself to b levels. Perhaps others can comment on this. Regardless the b speed is most likely faster than your internet connection anyways.
barbapapa wrote:
I would like to update my linksys 802.11B with a 802.11G instead but can I keep my same WUSB adapter 802.11B or do I need to replace them also? Thanks.
