Encryption setting won't save in Router
Oct 23, 2005 2 Replies
Hello, I have a Belkin Wireless Router. I have one computer wired to it and another I use wirelessly. Everything is fine when WEP securitiy is disabled. However when I access the Router through my wired computer, go to the setup page (192.168.2.1), click on Encryption and select the
64-bit manual option and enter my key and select 'Apply Changes,' the router does not save the setting. It always reverts back to 'Disabled.' I also tried with 128-bit, but the router is not accepting any security it seems like.
Thanks William, that was it. I was using Firefox.
Are you using Internet Explorer? If not, try it, some Websites (including some built-in webservers on SoHo devices) don't always work properly without paying homage to our overlords in Redmond.
If that's not it, try (re)flashing the latest firmware and resetting the unit to factory defaults. If different firmwares map NVRAM differently they may get themselves wedged without a full reset.
