128 bit encryption with DLink 624M router
Jan 17, 2006 8 Replies
Jump to replies (8)
128 bit encryption with DLink 624M router open original image
This looks like the right newsgroup for this question, but please let me know if I should have posted it to a different one.
I have recently installed a Dlink DSL-624M router in a friend's house; it all works very well except that I could not get 128-bit encryption to work. I tried all the variations I could think of to no avail, and the same settings with 64-bit encryption work fine. Googling about and having a look in the DLink forums, I saw that one or two other people have had the same issue, but I couldn't find a solution. The wireless network adaptors are the inbuilt ones that come with the Dell Inspiron
630M, if that makes any difference.
Does anyone know if it is possible to use 128 bit encryption with this device?
Regards, Arfur
To be precise a DSL-G624M, as in the following llink:
Many thanks for the quick response, I'll see if I can use WPA next time around his house.
Regards, Arfur
> Short
Thanks Frank, that does look promising.
Regards, Arfur
It isn't sold in the US, so isn't listed on
but it can be seen on
(as per Frank's link).
Regards, Arfur
you mean a DI-624M?
I had a nightmare with 128-bit encryption too (different h/w but same problem). I believe its to do with how the different manufacturers store the key (ascii, hex, numeric, spaces, dashes, etc etc). Despite trying two different routers and two different NICs, I never solved the problems.
In the end, I gave up and switched to WPA which worked perfectly. If you can do that, I'd recommend it. WEP is fairly poor anyway. Mark McIntyre
Have you updated the firmware? Long
. WEP Encryption Modes. - Shared and Open Option.
interesting - there's no such machine listed on DLink's website! Mark McIntyre
Long:-
that explains it, I was on the DLink US website. Mark McIntyre
