any suggestions for cellular<->wifi boxen? (fwd)
Sep 27, 2005 1 Replies
I've seen referneces to such but can't locate the brandnames... A box that will connect to the cellular/data network(s) and NAT out a WIFI connection.
( Mac Mini/Bluetooth/Airport? )
Presumably EDGE (t-mobile) but the backside specifics aren't critical. (within reason...)
Projected use is for a bus of laptop equipped yuppies and the like.
( I know it's doable.. there's a bus company offering this on a Bostan NYC run, but I don't know how they're set up )
tnx muchly
_____________________________________________________ Knowledge may be power, but communications is the key snipped-for-privacy@panix.com [to foil spammers, my address has been double rot-13 encoded]
